This is my dual drive 6" mini AT. Running flipsky 6355 190kvs and dual 4.2. Rode it for 12km in the morning without any issues.
As I was about to ride home after work. In the first few minutes I rode up a tiny kerb (1" or so). Once I cleared the kerb my drive started to cog and sputter.
I had a Bluetooth adapter so I went in and try to see what’s wrong. One of the motors just refused to turn properly any more. FOC detection was wonky, hall sensor would not even detect. Wires were intact and didn’t pop out. Almost certain the motor itself wouldn’t have been impacted because of the clearance with 6" wheels.
Now even with the motor running sensor less it won’t spin properly.
Anyone knows what might be the root cause?
Will try to disect it further on the bench but would be good to know where I should be looking.
well I guess it depends on alot of factors. if the magnets shattered or not and if they damaged anything else inside or not. when you open it don’t try to force a screwdriver into the motor to pry it open. because that can damage the windings when it slips… been there done that. just get rid of the sir clip and open it carefully.
have a look and see if there is a retaining ring for the magnets or not, glue them down if not.
For some odd reason, motor detection no longer works, neither BLDC or FOC. Either bad detection (BLDC) or R is 0 (FOC).
The red light on the ESC also blinks when I try to run the detection.
Swapping to another motor results in the same problem.
Now I suspect the DRV is blown, how exactly this would happen is beyond me. My only idea is that it was something to do with traction control (it was turned on).
Anyone else has any ideas before I swap out the ESC for a new one?
Nope… I swapped the motors around (known good motor to bad half of esc first)… Same problem…
Swapped motor on bad side to good esc side. Motor detects and works just fine…
So it’s basically a dead DVR or something else on the vesc. What I don’t understand is how this would even happen considering how slow I was going and the tiny obstacle I rode over.
I am certain my ERPM limit was set to 60k. Traction control was on if I remember correctly.
The moment I cleared the 1" kerb, the motor started to cog… Then the more I tested the worse it got until now where I can’t even get the motor to detect…
I don’t even know how I managed to get it to detect on the bench last night.
