Scarlet Spider | Custom made Carbon Fiber Unit P2 P38 Bullet 38"x10" | Evolve GT Truck Assembly |1 Set (4 pc) 83mm x 52mm Color Wheels - Red | Dual Rear NeoDym C6364 245kv | 200a ESC | Carbon Fiber custom Enclosure | 2x Multistar 4s Battery Pack
@XvDarkVAngelvX Would you like to come live in my shop? I’ll feed you and take care of you and give you a place to worship Skatan as you see fit.
I think recruiting members for a cult is against the community guidelines :astonished:
…then we need new guidelines. :grinning:
@pat.speed, was going to hook up in parallel and see how well they run. Never used these esc’s before. Let me test first then I’ll try to go up. If I don’t blow these first. @longhairedboy, thanks guy. When I come down under. I might need a place to stay. I’ll take you up on your offer. :grinning: I’ve seen pics of your workshop. I know I would have a blast. Lol
Cult! Thanks! i was wondering what this was called. Needed that info for my taxes. That reminds me i need more ritual gowns, i keep burning holes in them.
Sweet build dude! I have been thinking about doing a build with these evolve trucks myself, But i haven’t been able to find any measurements for them, How much distance is there between the motor mounts, what is the distance between the motor mounting holes, and how high are they from the ground?
At 16.7volts the display shows 100%, but at 15.7volts, the display still shows 100%. Something seems wrong there.
Yes I only just realise that when you pointed it out
Yes, the voltage meter wasn’t working right. I’m currently changing it. I’m going to make the enclosure longer and upgrade the ESC with dual Vesc.
Did you setup the voltmeter to your S count?
Yes I did. Something was wrong with that one. I replaced it. Now the new one works great.
Yeah they can be iffy sometimes, I usually order a couple, pick the “working” one and return the rest :yum:
Nice work mate, did you end up modifying the motor mounts for the larger diameter motor mounting? Asking because I am using the same trucks and mounts and just figuring what motors to use.
Great idea to use the basket for the framework for enclosure! Simplifies the whole process.
Nice! How do the new trucks feel compared to the old ones?
This board is very stable and non-flexy. Very strong and durable. I love this style a lot. The trucks are wonderful and turns great The stability at high speeds are good, no wobbling. I recommend both, good quality products.
IMG_20180624_174309701_HDR
IMG_20180624_180545250
IMG_20180624_180834564
IMG_20180624_180812652
IMG_20180624_180634297
IMG_20180624_180753553
IMG_20180624_180713903
