Second Build | OM5065 Motor | Enertion 10S3P | Ollin Vesc | Caliber II's
Hey, so my first build worked great but I’m focusing this board more on aesthetics. I may upgrade to dual 6355’s in the future but I’m on a tight budget so this is gonna have to work for now. (I’m using the old motor)
Parts List:
Motor - http://bit.ly/2eMD3P1 - $90 Trucks - http://amzn.to/2xdV6VU - $40 Battery - http://bit.ly/2iPM7Hv - $350 VESC - http://bit.ly/2gv0Sum - $160 Wheels - http://amzn.to/2wYSz5d - $60 Riser Pads - http://ebay.to/2eMJlhJ - $10 Mount - http://ebay.to/2wuxIUl - $45 255 Belt - http://ebay.to/2wYScYc - $6 Pulleys - http://bit.ly/2nTGOaQ - $50 (Bought all pulleys separately)
Total: $811
The deck I’m using is called the “Sector 9 Bintang” which I think was around $90 -$ 100. The mounts are enertion clones but they work great. I’m using a 36t pulley for Orangatang Kegels, and a 16t pulley for my motor (8mm shaft)
I’m also using angle risers because of the mount and how you can’t adjust its angle. The back trucks are already assembled which explains why I only took a picture of the front two…
Enclosure for the battery? Honestly I would go with MBS wheels. <== Looks more agressive. https://www.amazon.com/dp/B074DGD33X/ref=twister_B074G95LP5?_encoding=UTF8&psc=1
I have an enclosure specifically designed for that deck. Let me you if you would like one.
Oh nice I didn’t even know they sold them anymore. I have a spare pulley for flywheels so maybe sometime in the future i’ll upgrade. (Already bought most the parts)
I was thinking of doing a two part enclosure design (boosted style) but for the shape of the Bintang. I saw your post in the past, was it easy fitting a 10S4P battery in a small enclosure? Ps I’m using my old enertion space cell pro
Update: I stripped (sanded) the paint off the board because the sector 9 design was a little too much with the green, black, yellow, and orange. Like I mentioned I’m using two angled risers because the enertion mount clone is not adjustable. My Pulley setup is 36t/16t
I should’ve done more research and get the MBS since I’m annoyed with the Fly wheels because they make so much noise riding on the sidewalk.
Looking forward to following this build! :smiley:
How well does that motor mount stay on the trucks?
Very nicely. Since it’s a two part clamp, I added some aluminum foil in between the trucks and the curve part of the clamp, and that made it a very tight and perfect fit.
Everything motor wise is done. Since I’m upgrading to dual soon i’m using my motor and battery from the first build (since I hit around 25 MPH on it) but I also want to make a two part enclosure one day with a more compact 10s3p battery.
I’m thinking of getting a bamboo veneer. Anyone know where I could get a single one?
Planning on getting this for my remote.
http://www.ebay.com/itm/Mini-Remote-Controller-w-Receiver-Electric-Skateboard-Longboard-2-4GHz-US-Seller-/172832554248?hash=item283d9f7d08:g:LQAAAOSw8HBZHJzc
That safety warning though…
Did scare me but I’ve heard really good reviews with it and it has the same insides as enertions. I don’t know man
I am just a beginner, but I finished my board a couple of weeks ago and I started with the Mini Remote Controller, but I have to say it lost signal all the time, my body even blocked the transition when moving my hand.
I recently switched to the New Maytech MTSKR1712 Remote and boy what a difference. Also this remote has two start modes, normal and soft start, which for my over-powered board was perfect.
Redoing the grip-tape and clear coating (polyurethane) the bottom. I may pick up grip-tape Tuesday
P.S. The polyurethane will dry satin and even (it already did.)
I could build a two part enclosure for that deck as I have a Bintang laying around.
I might be making a 12s4p enclosure for the battery and a dual Focbox enclosure for the VESC
Oh do you think you could make a 10s3p enclosure with space for a BMS and another enclosure for 2 Ollin Vesc’s? Also how much would it cost? I’m on a tight budget.
Yes. Give me the size of the ollin vesc enclosures
Incase you wanted the Vesc measurements I included them.
