This really is a super sick build, this thing is so dam clean. Props my dude. Excellent work! You take it out a few times yet?
Thanks no it’s an in progress build, just finished printing out some TPU plugs for the unused holes, sitting on a riser I picked up here
The printer runs a boden volcano, not good for flex, so scissors to trim up the stringing
Oh and that’s a DaveGA housing yo the front, I removed some of the foam from the yoga mat and it looks better, still waiting on silicone sheet
Thanks
Here’s the plugs fitted
nice, can you share the 5mm plug files/(thingiverse link)?
I made it countersinked instead, neater and better for clearance
Sure ting
The cheap charge only bms arrived, look how small this thing is!
I bossed together something with @bevilacqua nose cad shame my printer isn’t good at TPU, too lazy to put together the flexion anyway
Will it work or even print? I don’t know
Nice move for the tiny bms ! If it finally breaks, this should be easy to do it in wood (plywood)!? And it will be stronger Plus now you get your pattern to draw it and drill iand use it as centered helper maybe !
what are the dimensions of the mini BMS?
So Tiny
It’s got me wondering if I’ve fmgotten something wrong
Size LWH 603410mm / 2.361.330.39"
It probably does not balance right, any suggestions?
I would guess it does not balance. I found something similar and it dosn’t balance either. http://litechpower.com/product-detail/HCX-D503V1LI13S15A-07.html#
well that annoyed the crap out of me as well, and it’s not even my board
good thing you took care of that @banjaxxed and this build looks awesome. didn’t see it until now and I have yet to scan through the whole thread…
I see it has overcharge protection. Is that the same as balanceing? The balance collum is blank. That’s why I ask
ouch, I was way to quick, no balancing indeed
Ok looks like I will have to spring for something like a Neptune 15 or jank cells occasionally, I may do this and some13s small bms discovery the riser failed, trying again
You can combine the bms with a balance board. I have a 13S laying around that I could mail you. You would need to solder the balance wires to the connector of the BMS/PCB. Staked over it should take the same space
This thing:
Thanks that’s mighty generous and a great solution
Yep, these are the little bastards that snuck into a battery or two of mine. I have some balance boards to try and some 140s to replace them if not.
