SInce this community helped me out so much with the build, I figure someone on here should get a good deal. The whole kit has less than 100 miles on it. Cost for the build was around $600, so I’m letting it go for $500. The motor mount was changed to a BuildKitBoards mount. Buyer pays shipping from Brooklyn NY (17 lbs) and I’m not looking to part it out.
I never maxed out either the speed or range, but I got it up to 18mph and there was still some trigger pull left, so if guess maybe a 20mph top speed. I’ve done 12 miles on a charge and still had lots of juice left, though I don’t remember how much. My best guess for range would be 15-20 miles on flat ground around mid throttle, but don’t quote me on that. Note: these numbers were with the ESC set to BLDC. Those numbers may be different now that it’s running FOC, but you can always switch it back.
