I would suggest Eskating sealed and sensored motors for the next time never been so satisfied with a motor https://eskating.eu/product/eskating-pro-motors-6374-190kv-waterproof-sealed-and-sensored/
Are these from Maytech? At least they look alike!
yess! and 190kv!
For my 12s on 15/63 pullies 179kv is going to be perfect, much more torque
What happend with your powerplant ? 6374 230kv Will fit my 8s perfectly
How do those sealed Maytech motors compare to an SK3-6374? Seems like they would overhear easier
All gone. Sorry.
have you checked under your bed or in the box in your fourth room? really need one
I got really good feedbacks on them, and since I have a dual 6374 on Trampa I can confirm they won’t heat too much because of sealed can. They perform so well!
I think you can find lots of satisfied riders here, @okp too !
yeah, fully agree with @fottaz . thanks a lot bro for the friendship. I’m actually testing the Trampa 158kv and will report back. It’s cold freezing in Paris.
It’s freezing here to man, better to get a break!
thanks a lot to you!
Im pretty sure those 158kv from Trampa are awesome too! saw some videos, good torque
How many of those RedEmber boards does your mom have now? Does @treenutter know what she’s doing with them?
I found a couple of the 6374 230kvs. Want them?
Any suggestions for a 12s setup emtb sensored, FOC happy and lower than 190kv?
APS 6384 170 KV, sensored
I also have those, pretty good so far. However, take into consideration the shaft diameter is 10mm
Hi guys i have two TB 6374 190kv motors with 12s2p battery but i have so bad range on it like 7miles or so, and i have set in vesc only 40A max per one motor, i using 90mm wheels and 16T/36T pulleys. I wanna change motors to smaller or idk , just to have more range, witch ones are good for range ? Just wanna use 12s battery cause cost to much to changing that to.
