What is the difference between the canbus cable and a servo…I’m so confused and I’m sorry!!!
The Canbus cable connects the 2 vescs and it has 2 wires. The servo cable connects the receiver to the vesc and has 3 wires.
Maybe this will help you.
Can you check my diagram?
Can you look at my drawing pls!
Your drawings are fine. The vesc with the receiver plugged in is the master and the other is the slave. Use different ID numbers.
Id numbers? What are those?
You will find the information in the link I posted for you. Master has usually ID 0 and the slave has ID 1.
But, what are the ids used for
To set master and slave esc
