Hi, buy the Flipsky VX 2 pro control that has the option of switching between 3 speed modes.
My build is Direct Drive elofty + vEsc 4.2 dual plus + 10s4p.
I already set my vEsc with the vEsc Tool (it’s not my first build, it’s already the third one). But all my remote controls were always more basic.
Is there a way to set the maximum and minimum of each mode?
Stan8
February 22, 2020, 10:11pm
2
Speed modes changes the acceleration but not the top speed of the board.
Hey, @Waiboard . Following because I have a problem with my control that doesn’t allow me to change between modes.
However, I’m imagine you would need to use a BLDC-TOOL. I understand it’s much like the open vesc software, but apparently it’s possible with it.
Here are some topics about it:
Hello
I want to represent my modified BLDC-Tool with modified Firmware.
The main goal of that modification is to have maximum possible control over the board. Because i didn’t like that i can use only 50% of my throttle at higher speeds.
And the second big thought was to have cruise control via PPM with my mini remote. Just simply because it is possible.
And after a while of fine adjustment, i found out that also a throttle-curve adjustment is necessary to have full control for high power board…
Hi. I was wondering if it is possible to make different speed modes with a VESC?
Just like the ones boosted board has. Like Sport mode and so on. So i can controll how fast it accelerates and so on.
If you succeed, please let me know, as I’m not very experienced yet.
@thi4g0tk Thank you very much! I’m going to look at the information
