Hi guys…
Yesterday evening my board was suddenly slowing down and stopped even though my cell voltages have still been at 3.7 volts. So I charged everything again and wanted to start up today.
I have a 40 amp fuse installed which gets fried 2 seconds after the start up of the esc.
I am using a 6s setup, a trackstar ESC and a turnigy 6354 esk3 motor.
I think I might have a short but I am not sure.
The problem occurs with 2 different battery packs which are both fully charged and balanced.
How do I determine if I have a short in the motor?
I checked my cabeling and it seems to be ok…no difference to the day before yesterday as I can recall…
So, I disconnected the fuse and connected the track star (only) to a 3S battery.
The track star started to smoke… So I guess there is a short circuit inside the ESC
a 40amp is definitely too low for a 6s system. And normaly you don´t use a fuse there. If just from a standard connection on startup without load causes smoke on the esc, i´d say that there is a big problem with it!
Like i said before, check everything and measure everything, before you fire up more things @Vaulter92! Sorry if i wasn´t clear that you do that before you try to connect something again to a smokin esc.
Use a multi meter to try and find the short. Definetely a short somewhere hence your fuse blowing. Most people build whats called a smoke stopper. It will light up if something is shorting. This way you dont ruin your electronics on new builds. I build mini drones so im accustomed to making sure there are no shorts anywhere.
So you overheated the wire by pulling too many amps and suspect the wire shorted to the stator. A clear indicator of this is that the motor will draw huge amps. Hopefully your ESC will cut out quickly or you are in danger of damaging your ESC and Battery. To test if your motor is damaged do the following:
Setup a continuity meter or "Ohm Meter". Normally they will beep or show continuity when you touch the two leads to each other.
Disconnect the motor from the ESC.
Optionally remove the bell from the motor so you have easy access to the stator.
Hold one meter lead to any of the three leads coming from the motor.
Hold the other meter lead to the stator. The stator is the metal plates that the wire is wrapped around. Touch the side facing the magnets.
If you meter beeps, or shows continuity - you have a fried motor. You can fix the motor by rewinding it. But this requires knowledge of how to wind motors, time and materials to wind.
Your esc should not pull many amps at all when starting up. Its either your esc or motor. Most likely your esc imo since you should see smoke from the motor if the motor is shorted or see your windings burnt.
It’s definitely the esc. The fuse was burned when the motor was disconnected. I’m running with half speed now and the switch that came with the esc can turn it on but not off. I find that very strange. Thank you guys for your comments. I will probably try to get a replacement from hobbyking.
