can you give us a brief description/ details ? what happened ?
p.s. my finger hurts from scrolling
Hope that switch is temporary, wont last long
Not sure where you are seeing a short, if you probe 5V to gnd, on one side you’ll see the tvs diode, on the other it should be open (but your meter will initially beep because of the caps)
Why did you remove the usb?
Check your PM… sound like a busted Can Tranceiver
