Alright guys I need some thoughts. I’m at the end stages of my second build and am running into an issue to where the lipo’s along with the concave of the board are causing the corners not to fasten down.
Initially I went with 10mm internal thread locks and screwed down the enclosure with m4 bolts. Wanted to go a simpler, cleaner way since the screw were giving me a hard time so I went with the 3m dual locking velcro. The stuff seems legit I just am wondering what I should do to get the velcro level? Should I sand down the enclosure area so the lipo’s will sit a little lower? Thoughts?
Ok. I’ll use the Velcro for a little as I spent $35 on it! Expensive Velcro but the pointers are helpful. Thanks!
I would honestly grab some inserts
Here is a guide how to drill them
Here is a link to them
https://www.amazon.com/dp/B017NENNVS/ref=cm_sw_r_cp_apa_i_k6HdBb28HVEQS
https://www.amazon.com/dp/B01NCJHLR7/ref=cm_sw_r_cp_apa_i_C5HdBb8R86F70
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F122456181943
For the gaps. If your in the US, go-to a Michael and get some Neoprene art Foam sheets and cut some in the outline of your enclosure. To put between to fill the gaps.
@Deckoz you mention m4x20mm hex socket head screws to go into the m4x9.5mm nuts. Is 20mm going to be too long?
Also when do the washers come into play? Do I really need them?
Washers widen the head of the bolt to provide clamping force. The heads are narrow and can pull through plastic enclosures like yours from vibration. Use a regular washer if you don’t want the anodized fender washers.
As far as the length. 20mm will give you enough room to make full contact depth of the insert. Plus a washer, and enclosure and foam.
The height adds up. If you think it’s to long try 16mm m4 instead. But a bolt the same length as the insert will do you no good. 20mm bolts work for most enclosures available.
