Would love to outfit my board with a VESC Telemetry Monitor (a small OLED Display) in the TX.
I know how it “therotecially” works but thats where it ends
The are a lot of Libraries for this kind of I know - but honestly - is somewhere a complete guide of how to do it ?
Here are also a lot of posts about the different ones - they all look nice but nowhere a description of how to do this.
I dont mind if it would be via NRF or BT.
I know its your hard own work what you did - but no one here to share their codes, schematic or am I just to stupid to find them or do this my own ?
Thanks already in advance
oh I did have a look there - but was looking for a “simple explained” solution - I am not very deep into coding etc
You’ll need to know how to code - http://vedder.se/2015/10/communicating-with-the-vesc-using-uart/
I think there some solutions people have made where a BT link to a iOS/Android app
Ardunio example: https://github.com/RollingGecko/VescUartControl
I’ve got it running currently with rolling gecko’s code, a 0.96" OLED, custom case, and thumb wheel. Planning to open source all my designs when I’m finished testing
You got a picture of this?
I always wanted to have a display like that on my remote or board, but I found the iphone route much easier. I plan on making a holder that is attached via the truck holes so you can attach your phone to your board to see the data without having to hold it. Seems like a simpler solution then programming these displays.
I am not sure if i would want my phone cms away from my feet and the groud while rideing on a vibrating and shaky board. They are kind of expensive these days.
Just a thought, what if you made a square hole with a router in the board, and countersink the edges. Then use Plexiglas or whatever clear material on top as a cover…
Then small holes along countersunk edges of deck and along edges of Plexiglas, and glue neodymium magnets into those holes and BAM! you got yourself the ultimate Iphone case in your longboard
That’s a valid concern. It would have to hold the phone very securely, which is possible. The gimbel I use for my iphone for example a great example of a holding mechanism that would be hard for a phone to come out of.
In general, your phone should have a case + screen protector that will prevent any damage in most cases anyways. Your board shouldn’t be flipping over, and it’s not hard to avoid stepping on it.
Again, valid concerns, but I think theres easy safe guards to prevent the worst nightmare of your phone getting damaged.
oh yes - thats exactly what I was talking about - the small OLED display in the remote - perfect ! would love to see how you made this - that is right the stuff I was looking for great work !!
