I believe i finally have all the parts needed to start assembling my board. First problem i encounter is the actual wiring which i have no knowledge of. I was wondering if i would need to solder the wiring between the motor/esc/batteries(for charging) together or if there was a connector (prefered method) i could buy.
The motor wires can be connected in any order. If the motor is spinning the wrong direction, simply flip two of the wires an the motor will then start spinning the other way.
For this reason, it is nice to have bullet connectors (matching your motor connectors) that will allow you to switch the wires and disconnect them at will. That said, you could just solder them after making sure your motor was spinning in the right direction.
For the battery, I would recommend a connector. You really don’t want to leave your battery connected to the ESC at all times if you don’t have to.
It looks like the two charging connectors that come with your charger are deans (the dark red two-pronged ones) and an xt60 (the yellow one). So if you just buy a pair of either deans, or xt60’s for your battery and esc, then you’d already have the correct charging cable to go with that connector.
use 5.5 or 4.x bullet connector from Hobbyking. So you can easily attach and detatch. It that takes so long for you and you can’t wait any longer, you could use the cheap cable connector (for test only).
They can do the job to test, but they don’t handle the current you will be drawing when you ride on your board.
The bullet connectors are great, but I wouldn’t even bother with the cheapo testing connectors that Laurnts recommended… just have bullet connectors for the 3 phase wires (that match the ones already on the motor) so you can switch any wires whenever you want.
I Agree it’s not a safe practice! Since I live in a remote place of online stores with BS shipping cost, getting 5.5 bullet connector is a though job. This does the job quite well for testing BUT NOT RECOMMENDED to ride with it.
@Andrew You should invest in a soldering iron. You wont need to buy all these adapters, you can just solder on any connectors you want/have as long as it can handle the current.
All these adapters are gonna get annoying to work with
I personally use a three way switch to an external xt60 connector that allows for charge without removal of the battery. As for the adapter, you have to solder connectors, it took me 3 tries and ruined two connectors to get a good connection I was happy with, just don’t cut corners when it comes to wiring wires that are carrying 22.2v (in my case) Good luck and leave a reply if you need any help, I’d be glad to help!
I’m pretty new to rc/arduino/electric skateboard/electronics, but barajabali is correct. You won’t find many ready made connectors on line, because no one is buying them! Everyone makes their own. I would start with a soldering iron with a temperature control. Keep your sponge wet! You will in the end. Have fun.
Clamp the plug/connector with anything that can hold it steady and won’t melt , get it hot with the iron, feed solder into the connector reservoir, enough that the wire can be sub urged in it, put the tinned wire in it and continue heating till its sitting in a pool of liquid solder, don’t move it till it cools.
Getting lead solder and a higher watt iron made a huge difference for me. I don’t know what temp it gets to but it does it fast and fast is good when soldering
So one of my bullet wires keeps getting disconnected from my VESC every mile or so. Does anyone have recommendations on how to secure it so this doesnt happen? I feel like a gum type substance would work well but i thought the forum may have some suggestions @carl.1 !
You may also want to reconsider your wiring layout. Maybe you can change it around to give your wires more slack and prevent them from getting pulled out?
