Wich motor should I take for a 12V 9Ah battery
I am a lightweigt person and am not planning to ride any uphill as I live in a very flat area.
Would any of these two work for me?
Or
If you have any other idea, everything is welcome.
Hmm 12V is a bit on the low side, is there a specific reason you want this kind of battery? @koen1020
No not any specific reason, I could buy a second battery to make 24V 6Ah.
Do you think I need 24Volts?
@sandrewvdv
My setup is based on cheap, but still fast. I’m guessing this is also your goal.
I’ve bought a 260 kV motor ( altough I would recommend a 245 kV for better torque and larger size stator).
I paired this with 2* 3s battery in series giving me a 6s 5000mAh battery. A 6s battery is easier to charge using a cheap balance charger.
Also very important, dont cheap out on your ESC, buy a VESC.
