Sweet build! I’m also making a board which will be my first! By chance did you order the Nano from Enertion? My controller was delayed as well. Also have you expirience any any wheel bite? I’m on a 39in board and 90 mm wheels and had to buy raisers, hopefully that does the trick. Good luck wih your build!
Thanks! No, I got the Nano from ebay. Never had any wheel bites (so far). Good luck to you too!
Hey, This build has gotten some needed upgrades and the biggest and most visual changes are a completely new deck from Slipstream and new enclosure.
I have yet to do some wiring but there’s plenty of time to do that since it’s winter.
The new stuff:
- Enclosure from @psychotiller.
- LED Power switch from @VladPomogaev.
- Bluetooth module for VESC and telemetry from @rpasichnyk.
- Switched from Winning Nano remote to a GT2B which has been put in a 3d-printed Mad Munkey enclosure.
- 2x4s 5000mah LiPo. This is actually 1x8s which I split into two 4s packs.
- Changed the wires of my SK3 to silicone wires (http://www.electric-skateboard.builders/t/howto-sk3-silicone-wire-mod/15597).
- Battery indicator. (Will be installed as soon as I figure out how to have the backlight permanently on).
Some pics:
<img src=“https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/1/6/16f94d77e897b350933ef7883c7db6f202bd220f.JPG” width="666"height=“500”>
Cheers!
