But after looking through other’s posts it looks HUGE and looks as though there is no way it is going to fit. So does anyone have any recommendations on 50.6v mini bms?
Awesome, will go for that. All the anti sparks that I’ve used are pretty bad, what is the anti spark that you find the most reliable? I was thinking bkb…
I haven’t used the BKB anti-spark switch, so I cannot say. I know Jared though and doesn’t sell crap. That being said, I have yet to use an AS that didn’t blow within a few weeks, max. I pretty much use loop keys as my default now.
The anti spark switch from @3DServisas and @Kug3lis is the only one on the market with a pre charge circuit. All the other switches get slightly damage after every use.
@mmaner hate to keep bugging you, on the bkb website it says the bms is 25mm tall. ???. On the spec sheet it says it is 2.1mm which makes more sense. Which one is right?
