After my DIY boosted board build in August, it is time for a new build. So I am thinking of selling my board because 6boards is to much at home. Make a good offer & maybe it is yours. Price for build with almost new sk3 motor: 800euro’s
Specs: Deck: Loaded Vanguard - Flex 2 Trucks: Caliber II 50degrees Wheels: 90mm ABEC Clones or 97mm ABEC Clones or 107mm ABEC 11(you can chose) Enclosures: Eboosted enclosure Battery: 10s3p Li-ion 30Q with 60A high discharge bestechpower BMS VESC: Focbox Motors: 1x 6355 190kv alienpower Motor Mounts: Hobbyking Remote: Nano-x or Maytech remote Bluetooth: HM-10
Board is charged 15 times. Motor have some damaged. If you want I can hold the motor and motor mount, so you can connect a new one. Or I can connect a almost new sk3 motor.
All wires are routed in the deck. There are also light wires inside the deck. I have now a 42-12v converter inside the board for the lights.
Because pictures says more then 1000words:
