Aw great price. Just bought the unsealed version though so sadly I must pass this onto the next lucky bastard.
Unless you wanna trade for the mini rc trigger remote which I highly doubt.
My other concern is that I found that in order to use bkb push fit pulleys, I’ll need 90mm axles. I would really like to use shorter axles on tayto deck
Do you know the overall length of these cans with the nipples on the end? I found it pretty tight with the true 6374mm cans. That was with 80mm axles. I was using sixshooters with over 15mm pulleys though and the pulley bolts were close. @sender has had a setup like this on his lacroix I think or of course @mmaner Mr @psychotiller himself would undoubtedly know the way forward.
its pretty much overkill, but it never slips. take a lot of what hours to turn those belts though. with 15mm belts I use 22 wh per mile, with 25mm belts I use 28 wh per mile.
