Soldering bullet connectors onto ESC
Hi! I have a quick question…
I see that a similar question has been asked about the Olin VESC (link), but I want to clarify with this specific ESC.
I have this motor and this ESC.
The issue is that the bullet connector for the ESC are different sizes to the motor. The motor came with different bullet connectors that I can solder onto the ESC, but I want to make this this is the correct solution before doing this.
Is it okay to solder new bullet connectors on this ESC?
Thank you!
~Jess
It’s fine, just be quick and pre-tin the wires.
Personally I like to elastic band a pair of pliers to clamp the bullet. Then use long-nose to feed the cable in. Tin the cable and the connector prior. flux wouldnt go astray too
