would be ok for a mono but dual drive, it’d be 25a per motor. that’d be kind of limiting.
and sag at 10a is about .7v, so total sag at 10s would be 7v. heavy sag like that can cause issues at end of charge if vesc settings are not set properly.
can you link to the sale post? I’d use these in an extended pack of 7p+ if the price was right.
yea I think so, 10s5p will be kind of heavy for a mono.
consider, you’d get almost similar performance with a 10s2p using 30q cells, and if you can source them for less than $4 shipped it’d be cheaper than the 50 nc1 cells.
New they are €1.99 and if you’re running them in high parallel, they seem like the best buy, though I’d probably suggest 7P+ for the PF or NC1. I don’t know about the “new” unwelded NC1 cells from someone who only answers via private message, seems a tad shady.
