Hey everyone,
I’ve just received my space cell from Jason, only thing is we ended up having to get it sent in parts due to shipping regulations in NZ so I’ve gotta build the thing myself. Looks fairly straightforward for the most part, mainly just not sure about wiring to the BMS and battery.
Does anyone have schematics for the BMS (or even a link to more information about it?) or photos of their own space cell that they’ve pulled apart where you can clearly see the wiring configuration for the BMS and cells?
Here’s a few photos for reference.
Thanks, are you able to confirm if the cells themselves require any more connections between them? I’m struggling to follow how the 10s3p configuration works based on the current connections between the cells…
forgot to mention that pin 10 of your balance lead should be soldered to the same place as you positive lead on the battery and then 9 to the strip in-between group 1 and 2
Any possibility of you giving a basic description on how they should be connected exactly? First time doing this sort of thing so want to make sure I get it right I’m struggling to understand why they’re connected in groups of 6, shouldn’t it be groups of 3?
Actually there should be spot welding all the way down both halves of the battery…
So I don’t think you are ready to go with just wiring up the BMS. Unfortunately I don’t have my disassembled Space Cell anymore, but maybe @onloop or someone else who does have a broken down Space Cell can chime in here on which cells need to be connected.
Any idea why 4 of the groups would currently be connected in groups of 6 cells on one side? Does this mean I need to cut the connections to split them all up into groups of 3 or am I missing something here? Also a bit confused as to why one row has 8 BMS connection tabs (indicated by the bits of tape) whereas the other only has 3
The bms needs 11 connections, 3+8, for sensing each cell. The six cells connection is 2 packs of 3 cells in series, where i believe there’s something missing, is your connections from the top cells to the bottom where all your cells are unconnected. Then again, i can be wrong, i don’t or seen a space cell.
Like the 4th pic in my build before the battery is unfolded. Note that my pack is a 10S4P, not a 10S3P. So i have connections of eigth cells instead of six.
Thanks for all the input guys, I’m starting to understand how this all works.
The main thing I’m confused about at the moment is the placing of the stickers/connections for the balancing leads, eg. The group of 2s3p cells on the left has a connection for a balance lead on one parallel set but none for the other, as opposed to the other group which has two balance lead connections on one parallel set and one connection on the other parallel set. The same can be said about the two groups of 1s3p cells I have, one has 2 balance lead connections while the other only has one. Is someone able to explain the reasoning behind this? I would have thought that there would be one balance lead per set of 3 parallel cells?
Also, if my assumption about one balance lead per 3p parallel set is correct, does it then matter in which order each parallel set is connected to the BMS or do I specifically need to connect the numbers on the cells to the corresponding number on the BMS?
Looking at the bms I don’t think you hook a positive lead to it. I think it’s just like the ones sold by battery support where only the negative is connected.
Right that’s possible, my fancy paint drawing should read “POS to load” and “NEG to load”. Because the connections to the bms can vary from bms to another bms
Sorry would you guys mind confirming that last part? My BMS has 11 wires for connecting to the battery (10 white, 1 black) and as you can see in the initial photo, the battery has 11 connection points for lead wires. So do the numbers from @Blasto’s diagram correspond to the numbered wires on the BMS directly with the exception of wire 11 in the diagram which would connect to connection B0 on the BMS? ie. 1 - B1, 2 - B2 … 10 - B10 11 - B0?
Still hoping for someone to confirm the correct configuration for connecting the balance leads to the battery. Main thing is I’m not sure if the B0 lead on the BMS corresponds to the number 11 connection on the battery or the number 1 connection on the battery? If the second option is the case then I’d assume that every other balance lead from the BMS ‘N’ would connect to number ‘N + 1’ on the battery? Is anyone please able to confirm which case is true?
I’ve messaged @onloop but haven’t heard back from him yet so thought I’d check to see if anyone else knew
Hey @delta_19 would you mind elaborating on this a little? The BMS seems to have 2 P- terminals (Well a ‘P-’ and a ‘P-1’), which of these do I connect the xt60 to? I’ve been looking at @cmatson’s thread of his opened space cell for a while which has been helpful to some extent but his version of the space cell uses a different BMS with different connections. At this stage I’m also not exactly sure where the LCD, power switch and charging port are connected in the circuit. Any information on this would be greatly appreciated too
On the upside, I’ve made some progress with the rest of the battery. The cells are all soldered together and the balance leads connected
