I have just build this pretty cool remote. I have one quistion touch.
Anybody knows if the potentiometer for the throttle and for the stearing/Wheels are the same ? When i epoxy glued the potentiometer to the 3d printet enclosure, i must have used to much glue, because the throttle is not moving very nice anymore
You can use the steering pot, but they are not identical. Youâll get funny values like 500-800Âľs with 580 center. Itâs not unusable, but you need Ackmaniacâs custom firmware that can handle independent endpoints and midpoints. This isnât supported in the legacy BLCD tool.
You can also just pick up any old set of pots- as long as they spin freely enough.
(I used the greasy ones, and the resistance isnât too much of a problem.)
Thanks. I noticed that with the sparkle enclosure i have not the full physical throttle Range, as the trigger / potmeter allows. Any problems in that when setting end and midpoints Up in standard bldc tool ?
You might find that when your endpoints are correct, the digital midpoint does not match the physical midpoint of the SPARKLE. In this case, you need This firmware.
If your lucky, you wonât need to do anything. (but Itâs not likely)
best mod for me in 2018 thx @okp
your milled version never made it to reach the necessary amount of interest I guess?
one question I have, I just now have found this thread and where reading through.
I have seen that in previous versions there was a hole for the pairing button.
Is there a reason why you removed that?
If you have it on hand, could you also link the inserts you use for the V2?
i ordered some, but the walls are too thick and because of that they don´t fit into the printed holes.
The pairing hole is still here but way smaller. To me, pairing has to be done once, probably twice if you want to pair with another receiver. Just unscrewing 3 bolts makes more sense to me than having a pairing hole. When I designed this remote, I wanted everything to be minimalist fitting to my riding style.
