hey guys, I was wondering if there is a way to switch speed modes without the Bluetooth thing.
After some research, I can’t really find anything useful except finding my nano remote has a dedicated switch for modes. I tried the switch, but there’s basically no difference on the rpm(which I assume is the speed)
This is my settings and real time data of the two modes!
Yes that matters. You want to tune your max and min for the 100% mode.
But you won’t see the difference on the bench… essentially what happens is your throttle gets limited to 83% of the total capable throttle, and rescaled over the throw of the stick. This changes the ramp your dutycycle over the throw of the stick. But you need load(ie ride it) to see the difference. Basically this doesn’t limit speed except the very top, and really just controls acceleration
If you want to limit speed you need Bluetooth and to calculate and set a max erpm for the speed you don’t want to go over.
Low throttle input upside down without sensors can cause “rocking” or"cogging" where the drive train bounces back because there’s no load instead of tensioning. (Shouldn’t happen with sensors)
Put the board on the ground and see if it rolls like you’d expect while not standing on it…
