Hi All,
Thank you for your understanding and patience!
The final version open pre-order.
If you are interested, fill out the Google Form.
The Gears Drive Kit (one gearbox) is priced at 160usd + shipping
Would take around 4~5 wks to make.
A kit includes:
1x Aluminium Motor Mount
1x Aluminium Gear Enclosure
1x Aluminium Clamp
1x Steel 40T Spiral Bevel Gears (wheel)
1x Steel 20T Spiral Bevel Gears (motor)
1x VA-45 V-Ring
1x Axial Ball Thrust Bearings F8-22M 8227
2x 6706 Bearings
1x 3D print fixture
This gear kit is suitable for:
Calibre II and TorqueBoards Trucks
ABEC wheel (83mm wheel or larger)
50XX or 63xx motors (8mm shaft)
Related topics please refer to
https://www.electric-skateboard.builders/t/spiral-bevel-gears-gearbox/65255/1
Is it 83mm wheels and up? Or is that the max size
wouldn’t 20:40 be geared a little bit high?
It depends on the motor kv, with that gearing go with 170kv or lower
140kv racerstars would be perfect
yeh thats what id be going for!
@MorrisHsu is this gonna be like a thing where it’s get it now or never or will it be purchasable for a while? (i have no money atm lol)
@Idea is getting about 6wh per km when using racerstars and his gear drives
pat.speed:
6wh per km
my god i like the sound of that. next board for me will either be a 10s5p or 6p with these and racerstars on 107s, unity blah blah i want
I will start charging in mid-March and produce or book up to 20 sets. I will start the first batch and make it.
Andy87
February 13, 2019, 7:15am
#12
I would say yes if trampa doesn’t have a different hole pattern for the motors.
But probably you need to shorten the shaft like on regular gear drives.
exactly my question, thank you and makes sense
Sorry, I don’t have a Tramapa motor.
This is a picture of the motor mount for your reference.
Andy87
February 13, 2019, 7:47am
#15
I think the question is how long the motor shaft should be and how long the motor shaft can max be.
that would be interesting for not only the trampa motors.
I ignored this.
max motor shaft length of 35mm
Andy87
February 13, 2019, 7:59am
#17
@topcloud so the trampa shaft is 3,5mm too long.
Grozniy
February 13, 2019, 8:46am
#18
Can you make a gear for Surfrodz TKP?
Will normal drive be available to purchase later?
Maxid
February 13, 2019, 9:16am
#19
sounds like something a couple washers could fix easily
Andy87
February 13, 2019, 9:18am
#20
that´s a good idea!
or a 3D printed spacer you can just add inbetween the motor and the mount.
