Stock Alert - 236kv SK3 motors at hobby king
6mm shaft :tired_face:
Good looking out @Michaelinvegas, I got excited thinking I had missed an offering from HK!
But isn’t that actually a good thing? All the cheap pulleys from stores like maedler are with a 6mm hole until 32t.
The issue is snapping the shaft , but never used a 6mm shaft …
If you noticed, 6mm shaft is hardly mentioned and places like Enertion and DIY Skateboards don’t carry 6mm bore pulleys that I know of
yeah I noticed - but since the industrial pulleys all seem to have 6mm bores it could be perfect for beginners on a budget. Get one of those motors and a pulley for 4$, drill a hole in them for a grub screw and you are basically done.
Yeah get you…but motors such as these best left alone … Especially if you have the NTM 50/60 that has 270kv and 8mm shaft…and is $20 bucks less
Anyway…moving away from 50mm cans, aside from chakas …to 63mm only…
Ummm…That’s what she said…:stuck_out_tongue_winking_eye:
8mm shaft - In stock :slight_smile:
I have used 6mm shafts on a few builds… they are alright. but I have snapped 2 of them (after hundreds of km of riding) replacement shafts are only $5
Weird it says 1288g on this page but 858g on the actual product page. If it is 1288g that’s over 3 times the weight of an Ollin motor!
