I need your advice - my board has a weird behavior since a couple of weeks.
Whenever I start the board and want to throttle it will stop the throttle.
I will throttle again and it will stop for another 3-4 times and then suddenly it will work.
The VESC will print the following errors.
Anyone had a similar issue ?
I don’t think it’s fried as I’ve been taught that drv fualt is like a check engine light on your car, it could be number of things but not exactly the drv
Ok so after taking a closer look at Vedder’s schematic I think that you could test if the DRV8302 is still working if you just measure the output voltage at your PWM cable…
If you have a multimeter just check if your remote receives power…
Someone, please correct me if I’m wrong.
I was just assuming that he’s talking about a 4.12.
I don’t think so. Do you have a other vesc you could try it with? You could also try running it sensorless? (Wohnst du in Wien? Dann könnte ich dir eventuell helfen)
It could be anything man, maybe the silicone in some computer chip just took a poo
who knows
Your best bet is the wizard @JohnnyMeduse or @ThermalM16 for vesc repair, just remember that soldering a vesc requires precision… if you attempt it on your own be ready to take your time lol
I already replaced a DRV8302 on another VESC… however I don’t really want to change it if I don’t have to. With my hot air station I tend to fry them sometimes because my Temp is not reliably stable.
I think if the board runs after one minute I can’T imagine that the DRV8302 is fried.
It might be something else - but I will try unsensored mode tonight and see what happens
