man, these things are nice, and looks great on raw trucks:
question, this tiny little gap between end of hangar and mount, should i fill it with a spacer? or doesnât matter?
This is when I should expect the CF plates.
crossbars will be done on the 18th.
Itâs perfectly fine. The only downside is the motor to motor distance might not be 168mm it might be closer to 170mm.
I got 8 more sets still.
I just paid for another set! for some reason I ordered two sets of CF plates and only ordered one press fit mount
I thought I saw it somewhere but I couldnât find it. What is the OD of the part that goes over the truck (where pulley would be). Thanks!
@JLabs your pulleys donât work great with these mounts. A spacer between the bracket and the motor plate would solve alignment issues. But your pulleys donât clear the brackets.
Thatâs what I figured, but I have something in the works
It was designed with the pulley sitting over the end of the mount a little to allow use of 70mm axels. Your pulleys can be used with some longer axels and spacers though.
Awesome, thanks! Iâll pay for a set now
Still have some left? These are amazing. So much easier to install the mounts.
Edit: Payment sent for a pair. Thanks!
They look pretty good. But they have only made a few. Need to wait until they make 50pcs
I hope this works with the wider 6374s from BKB
I donât see why not but thereâs always a chance
Iâll let you know
Just realized youâre referring to the crossbars⌠I will not let you know
Thanks! they donât fit the TB218 with their fixed V5 mounts, the ânipplesâ touch. I mean I can use it, just without the cross brace that I like so much. These SR press mounts would be a fixed width, so if the motors fit, then the cross bar would fit. fingers crossed
Ahh then yes. I see what you mean. I laid it out by hand and there was like 2 mm of space between them. Might need some washer action.
@moon Am I still able to place an order for motor mounts? Just wanted to double check before I filled out the google form.
