Stupid question but I made a homemade bearing press and destroyed the bearings (also a 190kv 6374) would you share some instructions or a video of you putting the 3 6800z bearings back in ? I got them out the same way you did but getting the new ones back in is a bitch as they are so tight
throw your new bearings in the freezer to get them to contract ever so slightly and it will make a difference putting them in. Leave them in the freezer for like an hour or two.
Doe’s anyone know the type of 8mm brass washer? Where to buy?
I have seen them for sale but I can’t remember where I think street wing sell them separately and also one of the other ones APSor torque boards
Bit late now but I managed to find shim washers on AliExpress, depending on your shaft you need 8/10/12 ID. They come in various thicknesses. I measured both a 0.2mm washer and a 0.3mm washer on an APS 6384 A 6374 freerchobby had a single 0.5mm shim on it
