Apparently it’s what it is made for.
I am waiting for me to finish my enclosure and I will be able to report back if this works… (or maybe not if if doesn’t…)
I remember someone from the forum who I had absolute confidence at the time telling me this,
Also when I took apart my first garbage lead acid cell board the pulley was stuck on the shaft like this and was only removable with extreme heat.
And some serious heat. I have an electric plastic welding gun, (like a hot air gun) so temperature without the flames!
I’ve removed one without a puller, just enough temperature to break it down.
exactly. my way of mixing some loctite into superglue is not recommended but it is SUPER permanent, heat and a pulley won’t even get it off. A key and keyway are still 100% necessary if you go this route
