Teemo M1-battery?
Pls,help…
I have the teemo board M1 and I would like a better battery (more range, even when the battery is running out of power). I want to buy batteries. not produce. price up to $ 250 (sorry-google translatešŸ˜) Thank you,Mark (CZ)
Are you asking about what type of cells to use, where to source them or if it is possible?
The Teemo M1 has a significantly improved battery (DOUBLE discharge rate than Samsung 22P cells) which allows you to maintain high speeds even when your battery is running low. I have an old battery and the power drops with the falling battery. and I would like to increase the range - and maintain the original performance. If possible, and if necessary some recommendations. I will search for links. (perhaps it will be understandable) thank you very much.
Are you looking for a prebuilt pack or the individual cells to make one yourself?
Looking at the Teemo M1, it looks like those generic Meepo type boards. Maybe @dickyho can help? Try looking here to see if there’s anything that would fit.
http://www.diyeboard.com/battery-enclosure-c-536.html?zenid=cseb4v2jqedmn9jdm7pb7mn1s7
This is what your looking for.
I would personally choose to swap batteries and buy a samsung 6.0 from ownboard.
Or you can get the sanyo which has like 25-30km range.
These boards all use the generic same stuff. Meepo, wowgo, ownboard, teemo.
