Hey guys, i have a fairly cheap 20 dollar multimeter and i went through and tested all my individual 18650 batters (samsung 25r) after i charged them and they’re between 4.08-4.12. I’ve built up my 10S4P battery pack, i want to do a last check to see what the overall juice of the pack is reading. Is it safe if i connect my multimeter to it? I dont want to blow it up with 40V
like the cheapest multi meters are rated for at least 500v or so it should say somewhere on your multi meter how much amps and volts it can handle
It will read a packs voltage just fine.
I know this isn’t your question, but still a good PSA, don’t make the same mistake as me trying to measure amps though, I’m going to guess your meter is rated for somewhere around 10A. To measure amps you don’t just switch the lead plugs, swap to amp measurement and measure like you do in voltage on positive and negative lead. You will short your battery this way, it needs to be hooked up in series on the positive or negative lead alone.
I did that two days ago and blew my previous multimeter, hence me asking just to be safe
Quick update. I just tested it and it was fine. Pack is reading 41v. Thats good right for a 10S4P. Next step is to do the motor config for my VESCs (via VESC tool) with the batter pack connected to test the motors out. Wish me luck, i’m sooo close to finally finishing this thing.
You are safe to use it to check voltage yes. Do not try to use it as an inline amperage meter though.
make sure your probes are connected to the correct ports on your multimeter.
i use this one, probes are connected in the circled ports.
the port on the left is for measuring current flow and will burn up the device if you try to measure high voltage / current.
Yup, i blew my old multimeter yesterday doing it the wrong way. I got a new one today and did it right, yay! learning!
I have that same cheepo. It’s been great for the price. I use a Fluke at work, but for home use these are totally fine.
