But if you write anything in there you are promptly chastised and your post flagged for deletion. So I thought maybe we could use this thread to discuss the images you people are posting.
As a loose rule, if you’re responding to a specific post, please be sure to link to it in your response here:
And maybe also call out the poster so they can see you’re talking about their photo.
-structure to the p-group
-common busses for welding
-easy to implement cell-level fusing
-easy to create flexible battery packs for flexy decks like trampa, etc.
-easy p-group maintenance/repair
Myself as well. I’m finally in that boat! Building buses with braided copper is a pain in my ass!!! And i have a few more builds in mind. Those ones look killer!
You can do that, or you just solder the nickel to the tabs, and then join them by wire / wire mesh. On our version you can solder a small jumper and have ribbon cable joining all pcbs to make balance wire on one end. No need for single wires all around the pack (prevents wear cut balance wire shortening in the pack or etc many fires started because of this )
