It’s a blood orange griptape
What deck is that btw? Looks like the wheel cutouts are big enough for pneumies.
I would guess omen barbarian
Yea it’s OMEN
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/305?u=pjotr47
Hehe
Just wait some days longer I send the customs the invoice before they even receive my package.
Is it possible to charge and monitor batt at the same time? Im using it to only monitor batt lvl, didnt think I could add socket to plug charger. Could you post pictures how you put it together?
Yes you can charge and monitor voltage at the same time, that’s why there is a charge port on the pocket voltmeter. Here’s the model and build instructions, you just solder the volt meter leads in the middle of the charge port and pigtail.
Thanks a bunch! Now I have to figure how to get rid of the hot glue of the pcb from my meter xD
Thanks again for the model!
No worries, glad to help.
Where did you get that voltmeter?
The whole setup or just the digital readout panel?
I read up on it. Found the thread on how to set that up. I initially thought that these were commercially available to purchase. I didn’t realize you have to make them.
I just placed an order to make it. This should help me see the volts and amps while I charge. Pretty sweet setup. I’m a minimalist. I only have the charge port and loopkey installed on my enclosure.
My enclosure is the same. Charge port and loop key
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/314?u=rusins Holy balls that is cool! It didn’t even occur to me that the thickness of the Hummie deck had such an upside! You might have just convinced me to use my Hummie deck for my AT build after all; I can imagine using RGB strips and an Arduino to have 1 side flash orange when making a turn
Yeah love this board for AT ! My led strips are controlled by my remote. Push a button and I got headlights and brake lights.
Thanks for that, I was having a hard time imagining how a strip would look
It looks amazing, just need to buy some of the waterproof ones
Do you plan to do the same at the front? Don’t know if it would light the road enough
Yes , I’ve got white for the headlights just haven’t put them on yet. They’re pretty bright at 12v , for me I just wanted to be more visible to others.
I think it needs a “my other golf cart is a skateboard” sticker
I though they were the adressable ones (ws2812)
I will try on mine this weekend, if it works I will get the 144 leds/m version
