Not sure about that pecker of yours, too small…
It seems the way you have mounted your stator is different from how elofty has. After removing the M12 nut, and all the tiny m2.5 bolts, I can’t budge the can. Take a look and let me know what you think
I think is the same except that they have rear bolts attached to the rear stator pipe. So once you removed all the screws the resistance you feel is the electromagnetic field and probsbly because the rear stator pipe is press fit with the motor can. To better understand I am pretty sure the motor Can can be removed and the rear balck plate stays there with the stator.
Shirley some mhistake?
Mine might not be super water resistant because I added a a kind of grille with a questionable water barrier. I only really want it to be reasonably splash-resistant tho. A bead of silicone around the perimeter makes a nice seal
it’s all I got :
What’s that deck with the pneumatics and the nice grip ? @Mobutusan and what is yours @pduck911
perfect! and, kicking myself for not buying a complete ha
Trampa Orrsom Longboard with Urban Treads. It’s a nice board but overpriced for what you get. Also you need to source your own battery. I went with the Trampa recommended LIPO battery and for the $$ I wish I had a custom 18650 battery built.
Thank you for the honest review
@brenternet https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/404?u=andy87
50€ for the tb110s plus shipping isn´t that a deal? nobody else would buy them off you!!!
More info regarding the project please
I’ll send you one wheel.
Alright! That is than 12.5€
are those 6 shooters, If so how much for the whole set?
Get off my wheels. I plan to never use any of them!
In case you missed this thread…
