[Text Responses] No words…just pictures delete words!
Yep… pretty sure buildkitboard uses them.
Also, is the extended shaft needed? And I have talked to them before, I think I needed to order 10 motors, but this was a while back.
If you don’t mind discussing, what was the deal you arranged with them
At the moment its just two sample motors, which sorts out my current build, but if they work out I was going to order more.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7124?u=b264
@oriol360 how will those stay on the hangers without rotating? Do you drill a hole all the way through for a pin?
They will probably work out. There was a successful group buy for them a couple years back I think
I found the thread for it, thats what gave me the inspiration. I’m using an Sk3 on my board now and it seems like they are one of the better motors out there, if they just came from HK with these mods already they would probably make a killing.
They really should do that lol
I wonder if the factory is good quality or if HK are just strict on what they sell and only sell the “good” motors and then just not sell the bad ones. There are very few complaints with these motors, considering how many people use them
I think that they think I’m a proper reseller. But with the trade war with the US they probably need to find some extra sales here and there.
I just got the sensorless 168kvs from HK.
As far as i know on a 20mm pulley, with thick chunky mounts it could do with a couple of mm, its short just under 4mm from being flush but its not critical as the pulley rim is one mm and the belt sits one mm in-ish from that.
ps my motors are jus test fitted with two screws at this time… dont panic
panic
Ordering a box load of ready to go sensor kits might be an idea… they would sell quite nicely and be cheaper to ship worldwide and shizzle.
Ide be in for a couple.
Yeah there are two grub screws that hold it in place. They dig into the truck really well when torque down.
Just shipping the sensor is one idea however it doesn’t solve the phase wires or the shaft.
20180316_211233 This is my current Sk3 with TB mount, the 3-4mm overhang isnt a massive deal but I just don’t like it. The keyway is a bonus too.
@walleywalker , what camera is it? An video that shows quality? https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7143?u=mishrasubhransu
Mobius Actioncam. It’s setup for 1080p @30fps with a 135 degree fisheye lens (eBay sourced) right now. The housings are custom and 3D printed and there’s about 15" of extension wire to the camera module from the PCB. Video is great in regular light but gets a little funny when it’s dark. I’ll see if I can load up a ride video in a bit.
You are aren’t you? There can be only one. You get that off the ground then enertion will hate you and take back the title. lol
image And this after I have just cut a disgusting great hole in a work of art.
I’d be happy to share the STL and parts list, but I’m 95% sure the setup will only work on the particular Bern helmet I have unless otherwise modified.
Here’s the video quality from the helmet cam.
imageLOCTITE 638 is designed for the bonding of cylindrical fitting parts, particularly where bond gaps can approach 0.25 mm. The product cures when confined in the absence of air between close-fitting metal surfaces and prevents loosening and leakage due to shock and vibration.”
Video quality is pretty for. I would be able to to the CAD stuff. So there Mobius action camera has an in-built camera, do they have a setup with external camera? Do you have a pic of the setup before mounting everything in the helmet?
My suggestion get fur for your microphone to hide those wind noises :slight_smile:
