That’s when someone tried to post a link to TorqueBoards. Jason blocked it LoLz
That is kinda low.
its real messed up. Jason always bringing the drama.
@Chase I’m trying one of those micro BMS from ebay, one of the 10S ones. But only one. I’ll let everyone know if it fails.
I’ve got one too, I’m keen to see how it goes
Those bt modules, I’m taking it the green is good and red is bad. As in good and bad you mean work and not work yeah?
Yep
This is the one I have on a 10S6P
Is it something you can trust
This is mine, waiting to finish my dd before I can test it. It’s also got temp, I think
We’re gonna find out LoL. I’m still using a besttech in the new battery I’m making right now, if that tells you anything…
I’d expect to hear about it if someone has one fail…
Guys any reports on those? https://www.aliexpress.com/item/10S-36V-Lithium-Battery-Protection-Board-BMS-with-balance-Waterproof-18650-lipo-Li-ion-16A-25A/32839578059.html?spm=2114.search0104.0.0.369d13e1CUOWkl
I’ve saw one guy buy like 3 and none worked, they all smoked. Mind you it could easily have been user error, he was quite new if irc.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/8168?u=pat.speed Looks sweet, just wondering how come the motors are mounted so low (almost parallel with the ground), I’ve see a few boards like this and don’t get why. Is it a mount issue that restricts movement? Or hitting the deck?
Anyway looks great. I do have to say tho, I have a sweet spot for GTX’s even tho the bad batt and remote they just look so cool
just cutting some test pieces to check size and fit for some trampa motor mounts
i’m curious why not many more folks are into the DieBieBMS
Cost, size…
i want to love it. its massive though.
I didn’t think it was much bigger than the supower bms that has a high fail rate.
I’m going to try and jam one into my hummie build, mainly because the flipsky 6.6 dual doesn’t give me accurate voltage to metr…
2x the size of d140
