Only thing is that you need to flip your wheels. The tire tread is going the wrong direction. The V is supposed to be pointing forward, the point being that any water or debris is being pushed outward not in.
Are you running two middle pieces with two outers for the wheel pulleys? Any issues?
Both, the BMS will cutoff at 42v and start balancing. The Luna Charger will drop from.4a once it sees 42v at the pack. Itās meant to be a dummy proof system, although itās still safest to not charge unattended.
Had an issue with my old ass VESC-X, the USB port broke off and was shorting something inside the case causing cutouts. Replaced with FocBoxās and sending the VESC-X to @JohnnyMeduse. Also upgraded to @Ackmaniac firmware 3.1 to try out current & reverse, not sure I like it but we will see.
Looks like it wasnāt the VESCās. It cutout in me this evening in a rise downtown. Iāve checked all the wireing, it might be the remote but I think itās the battery pack.
Iāll test another remote to tile that iut but I guess I need to find a charge only 10s BMSā¦
One of those two for sure. Hopefully the remote haha, way easier to fix. This is a beauty of a build. Mike, how many full working setups do you have at any given point?
Right now I have 4ā¦ bludgeon, gear drive, pintail and caldera. I gave my brother one of my evos and Iām currently rebuilding the other as an ultra low thane boarf I took the FocBoxās out of my spud but Iām short pulleys for it anyways. The bludgeon is my favorite touugh.
Also, @sender is doing some mondo cool stuff to a caldera for meā¦shhhh, it a a secret
I wish i could like something more than once. Pretty sure Iāve guessed it already, but looking forward to seeing the end result.
Ya seems like one needs at least two builds at all times to be able to safely have a deck when the others being worked on.
Hi Mike,
Iām interested to see your @psychotiller mounts. Do you technically have them mounted upside down? Iām setting up my surfrodz and tiller mounts now but thought the thicker part went underneath as motor protection?
Iāve done it both ways, depends in the deck. Sometimes if I have shirt clearance, from the motor to the deck Iāll out the thick part up so the motor doesnāt hit the deck. If I have plenty of room Iāll mount the thick part down so the motor canāt hit the ground. Is that what you mean?
Thatās what I mean.
Iāve sat for a while last night working out how to mount them and come to the conclusion like you that thereās perhaps no right and wrong way!
I think so, most of the decisions in how to build are made based in the environment and materials. Thatās whatās so great about @psychotiller mounts, they are very fluid in how they can be installed.
Nope, there is 5mm max between the motors. Buy I canāt imagine anything bugger would matter, the TB 6374ās with 10s will do 30mph on 6erās, 22s would do 35 easy.
Yep,. Iām building one too with TKPās and 6 erās. Finally got my motor gears in and they are hardened so I canāt get a dect tap for grub screws. Guess Iām ordering again.
