Hi to all,
so many time lurking this super board so i decided.
Please help me checking my parts.
Many years on skateboard…never been on a longboard
A super important detail…i’m aa Italian big boy of almost 2 meters tall and over 100kg weight.
I will go on a 9 strate board that i want to cover with carbon fiber myself for estethics and strenght.
here my part list:
3x series Turnigy 5000mAh 3S 25C Lipo Pack W/XT-90
Turnigy SK8-ESC V4.12 For Electric Skateboard Conversion w/BEC
XT90-S Anti-Spark Connector (2pairs / bag)
Anti Spark switch led
Turnigy Aerodrive SK3 - 6374-192kv Brushless Outrunner Motor
Turnigy Skateboard Conversion Kit Spare Parts - Motor Mount
BMS 10s 36 v 16 A
Motor pulley 18mm x 19mm
Wheel pulley 52mm x 20mm
belt 155x225
Wheels Urangatang 80mm (have te right holes right?)
in this specific motor i have to work on shaft right? a bit scared about but the motor itself look very shiny
Your bms is for a 10s pack. Your pack is 9s. Everything else looks great.
It’s not hard to work on the shaft just go slow. When working on the shaft of the motor make sure you cover the motor so the metal isn’t pulled into the motor by the magnet.
I love the name
Super!
About the bms i cant find a 9…only 6 or 10 here in Italy.
I was thinking that i can not plug a wire…no?
Another concern is about wheels…nothing more cheap pre-drilled?
Hi! Nice to see someone from Italy too. I recently gevw a lot of advice to a guy that wants to build a single drive board without spend a fortune. All stuffs from AliExpress, Flipsky, hobbyKing (there is a discount code in the thread, like hobbyKing10). Maybe you can go through and compare with what you have and what we said. In your list I don’t really like the 80mm wheels, they will give you really short clearance from the ground. Plus the motor mount is not great the one from hobbyKing.
Thread https://www.electric-skateboard.builders/t/electric-longboard-beginner/65465?u=rey8801
Read it carefully and you will find all the links you need. Ask in case of doubts. There is listed all the parts to save money and have good stuff. Of course you can go always higher. Good luck
Hi Rey,
i know that the hobby King Mount is crap but is Easy ti find in Italy and cheap.
If its fine to ride in Bologna i Will update the boare with a better Mount and li ion batteri pack (DIY).
In next few weeks the build start and i’ll upload Photos step by step.
Motor shaft is pretty easy to grind away with a Dremel metal cutting disc but can do it by hand as well with a file if you have enough patience… The Dremel is much faster.
