This is going to build my first build.
I tried to save as much money and still make a high quality board. I would like to try to 3D print the drive system, my dad has acsess to a 3D printer (uprint se plus)
These are the parts I have decided on so far. (already have a remote)
Trucks = caliber II 50
Wheels and bearings = 90mm flywheel clones with abec 7
Motor plate = 3d print
Pulley system = 3d print
Motor = http://alienpowersystem.com/shop/brushless-motors/alien-6355-outrunner-brushless-motor-190kv-2200w/6
ESC = Vesc x
Battery = https://www.streetsaw.com/products/one-wheel-electric-skateboard-battery-replacement
Deck = Originalskateboards pintail 37
Do you have anything that could be improved on this build or parts that you can recomend.
BTW if you are wondering why the board is called “the kic board” it is because I am creating it at KIC (Kongsberg Innovation center)
Edit:
I will no longer 3D print the motor pulley and the motor plate. I will buy UnikBoards motor plate and pulley. I have decided to change the esc because of the unknown delivery date of the vesc x. I will buy Unik’s vesc. (Just because they are located in europe)
I will also 3D print the enclosure and risers.
I will also laser engrave the name of the board in the deck. I can upload pictures if You are interested:)
If You are wondering i come from kongsberg, Norway.
