What a beautiful build man. I really love the look and everything you used. What are the specs via range, top speed, weight, and acceleration? Also how do you like the flipsky 6.6 VESC and flipsky 6374 motors? I want to do a build with them too! I am looking to build an AT build and love the idea.
Thanks! Here are some specs. Top speed: 30mph Range: 12-15 miles Weight: 23lbs Acceleration: Canât measure it but it tackles every hill Iâve encountered with ease
The Flipsky 6.6 has been pretty great, itâs been quite forgiving of my initial mistakes in the beginning such as trying to run motor detection while the phase wires were shorting out.
My motors are 6354 not 6374, and theyâve been pretty durable. One of them has a noisy motor bearing, but thatâs most likely from riding around in the salted snow over the winter.
Feel free to ask any more questions.
How is the at performace with it? Iâm looking at the wheels wor my build but Iâm a liitle worried about the ride smoothness on gravel roads and such.
Where did you put all those groceries? Lol.
Beautiful build btw. Looks premium.
The wheels have been great. The tread design isnât meant for hardcore offroading, and neither is the contact patch of the wheel which isnât too wide. However, it has no issues handling gravel, grass, and dirt. Much better than your standard urethane.
I feel much more confident carving around corners due to the additional grip compared to urethanes, but still wouldnât recommend it in case you do lose traction. Comfort is also slightly better than urethanes when it comes to small bumps or cracks in the road.
I wear my large laptop bag to the store then play tetris at the register stacking everything neatly in there. Beats having to carry them in one hand.
And thanks for the compliment! Iâm happy with how it came out, except the bottom vinyl is peeling already so Iâll be taking it off and spray painting it white instead sometime soon.
Is the power of the 6354 motors enough?
For now yes, unless I update the battery to something that can push more amps.
Kind of random but what size deck exactly did you use and did you cut the ends to make it a âslide throughâ mounting open set up?
Howâs the 6.6 and motors doing??
How one knows where on the truck to place the mounts? It is kind of a silly question, but I was wondering how you know if the trucks arenât too far to the right or left.
Sorry for the late reply, I donât check these forums much anymore. The 6.6 I sold to a friend running 12S lipo pushing high currents and theyâve been perfect. My motor sensor pcb got fried after running in snow over the winter but the motors are still ok.
@Tarxan you base it off of how far your motor pulley extends, and align the motor pulley with the wheel pulley.
