I was supposed to finish the build and the make a thread about it but part of the fun is also sharing and documenting the progress, so I decided post now.
The Phoenix was sold after just a month of being built, so I used the money to make a similar build, slightly different but with the same soul.
Here are the parts I receive 3 days ago:
100 Samsung 30Qs Trampa 35 HollyPro deck Ultimate trucks Superstar hubs wrapped on 8" Primo Alpha tires
I quickly and desperately started to build the battery, when you make a build similar than previous one the dejavú feeling makes you build like a pro, everything is much faster, you even have the option to improve the previous design.
I used the approach from @chaka to have a safer battery pack, fish paper on this layout:
Then spot weld them, not sure if this could be called fuse cell level battery as I didnt use fuse wires on each cell, maybe the strip could act as a fuse in case of a short.
The enclosure was already designed on my previous build, so it fitted perfectly.
I used 16awg wires, a 16AWG wire should be good for 50A so I installed 2 of them for 100A max, the battery can only produce 80A peak so some extra room for peaks.
The HollyPro is slightly different than the HS11 deck, the main benefit is the weight, the HS11 16 ply weights 2926g, the HolyPro 15ply weights 2,570g, that’s more than 350g.
However the holes are going to be a challenge to work with, the nose and tail on the HS11 were used before for the on/off switch and battery capacity tester, the HolyPro have holes on there, I’m gonna mount a sheet of plastic to tap the holes in order to hold both parts.
