You could fill the hole with epoxy and sand it to get a frosted look that would diffuse the light
I was looking at the specs of the light bar, it is powered directly by the battery? That’s one road block I stumped on mine, using a 60 led/m strip I would need another DC/DC converter just for the leds
Light bar used , directly battery powered, the foward voltage of the strip is 48V (measured with DMM) the lights become dim as hell when around 41-40V… but for the simplicity of the circuit, i did not care. I’ve also added a little 15ohm 4W ballast resistor for when the battery are fully charged (50.2V)
I was contemplating on reworking the LED strip in to a 24V operational voltage, normally it’s 8 LED in series, i would have changed it up to 4 // 4. But didn’t do that, just used as is.
now that I think about it… I should just of removed one LED out of the circuit, making the forward voltage 42V, that would have covered my entire voltage span with minimal dimming… oh well, already made 8 holes, not going back
2 oz copper, no i haven’t used this bms before, i am already a bit disappointed by it, it has no balance circuit… oh well it will be good for charging and cell monitoring
yes i was planning on paralleling up the two 12S2P packs, that way i can use only one charge port… but i could just has easily run them independently, but would require 2 charge ports.
What about one charge port but connected to each battery with a diode? This way they will still be isolated and no current will flow between them, using a 0.3v drop diode should be no problem
i will be interested to see how this works out. I have a similar setup in my build where i have a 12s battery pack in an enclosure and i have 3 of them in parallel. in my last build i had to join all the balance points between all of the different packs and one big bms, but it means lots of cables between separate enclosures. I had been considering separate bms in each enclosure and just running power and charge to each enclosure but was concerned that something weird might happen.
im this close |------| to trying to make my own bms. but i already have so many projects on the go
do it, make a de-featured version of the DiebieMS, no need for high discharge, cell balance + monitoring, CAN communication, LCD port, Unity switch control, charge control. would be dope.
