Trampa has breaks you have to buy their trucks so you can mount them to it
Herringbone gear, the only problem is manufacturing, but they are not worth in our case, the axial loading exist, but itâs cheaper to solve by using the correct bearings and a new axle to support them than make a gear like this
lol you guys should stop hijacking this thread and come discuss on the dedicated threadâŚ
Good point - transferringâŚ
Thoughts on the meepoboard and definitely I assume more coming like it
Semi-diy and semi-not
Is this the new face of diy?
Could one put two opposite helical gears parallel to each other (on the same shaft), creating what appears to be a herringbone pattern, and cancel out the axial loads?
Yes, but by solving one problem you can end up with a lot more, of the gear are not perfectly aligned one half will take all the load, and making then aligned is hard, you could weld booth, but them there is a chance that the heat will misalign them further
