10 pole pairs
Huh? my app asks for motor magnets.
10 shows my max speed as 49mph.
magnets=polepairs*2=poles
??? I dont understand
Speed is showing 33mph… only clocked 29mph on gps durning ride which i think is normal.
sorry, fixed it
stick to GPS data, better that way
but gps disconnects durning range test lol, so vesc data is the most accurate
The motors has 20 magnets. In Ackmaniac app asks for how many magnets and Focbox UI asks for how many pairs of magnets.
Finally, I replaced the lid. Old lid was too thick and flat af. All 8 holes for mounting the hinge were literally unusable. They all striped within 2 weeks of use. Screws fell off during a ride and I was scare AF that it would short something.
Update:
- New lid clad 7065 1.5mm 21.125"x7.375" (should’ve gotten 7.5")
- Pop rivot to permanently secure the lid to the hinge.
Still need to do:
- Laser cut grip tape
- Drill holes for push button and charge port
- Cable management
Looks way better. Well done. Maybe put a foam or fiahpaer to separate the lid from electronics. I am sure you already thought about it
The only bad part is the new lid is a bit too flexy. I think I need to add a stripe of metal in the middle to stiffen it up and pretend that’s meant for W concave.
Yeah I’m too tired to think right now. Need to stop the lid from bowing up. Need to see if changing the underside of the lid to a full sheet will make that worse.
Well but did you actually stand on top of it? Otherwise I would maybe get a bit thicker lid so you can actually bend it to the shape you want or just add the layer underneath so you don’t see it from the outside
I’ll try the “W concave” beam first. Hopefully it would work. I really don’t wanna make another lid. Maybe I can see if I can remake my battery to make it 1mm shorter. It’s pushing the limits right now. Also not going down from 12s5p.
Yeh I see and why not add the layer inside? Of course eof there is enough space. It would look better from the outside
I see and why not stiffer only the edges (lateral) . I see quite thick foam there. You can add 1mm lid there and thiner foam.
Totally understand that you want to keep 12s5p otherwise why doing it
The hubs are thirsty af. especially going up hill.
We will see. Either 1 beam in the middle or 2 on the sides.
