Here is the issue I need to replace my shaft on 2 Sk3 6364 213kv motors the parts are not available and have not been for a while do u think Turnigy Aerodrive SK3 6374 Series Replacement Shaft Set would work with a bit of fettling? THOUGHTS ANYONE
let me grab a couple links bro, in short: yes you can use other shafts*, you can even make your own out of drill blanks*
might need some tools though like a drill press or a arbor press*
*I’ve got more experience pulling apart scorpion motors, ill be back with a link
read the links here on making your own motor shaft and changing your motor shaft, video inc.
Dude that’s all I needed to hear and luckily I have tools two garages full haha just wanted confirmation cheers
Ohh. I misunderstood the thread title Dissapointed:stuck_out_tongue_closed_eyes:
Damn Clickbait!
Came here to see some dickeldidoo
There are plenty of websites if that’s ur thing
Any of them have pics of your shaft? I mean your motor’s shaft. I think
Haha all is good ordered some 8mm stainless going to cut a new one
Have you pulled down the motor first?
My 8mm motor shafts actually taper to 10mm (9.98mm) to press fit in to the bearings…
I see no one has actually clicked on the link so I’m just checking, also the hardened steel used for drill bit blanks will be more durable than stainless
Yer got some calipers on be 4 I do any thing and gunna try stainless just because iv ordered it haha I used the link opens new tab rather than the link it’s self so won’t count.
