When I pull my trigger a bit to much I get thrown of the board, because the motor stops. If I carefully pull the throttle as I am picking up speed it works fine. Is there a solution to this? I want to be able to use the throttle without being scared of falling of.
My specs:
X-car beast 120A ESC
2x 5000 mAh 3s 20c in series
5070 Propdrive V2 270kv
Does this ESC have low voltage control? It might be that you’re voltage-sagging those batteries and hitting a threshold programmed into the ESC, which would cut power if you draw too heavily. That would explain why you can accelerate slowly but have problems when you go full throttle.
I am assuming you do not have sensors hooked up to the ESC. I had the same problem with my HK 150a ESC. I beleive it is a “safety” feature.My suggestion would be to use a sensored motor. This solved my issue.
The parts you have are going to limit what you can do. Start planning a new build using the parts you need to acheive your goal or buy the parts you need to make your current build work safely.
I have never used sensors and I have never had this happen with any of my ESC’s
I don’t believe its a safety setting. that doesnt make sense.
I also don’t change many settings on the programming card from the default. just max timing, and min punch.
I have used so many of these ESC’s I have lost count. never seen this before.
I done over 100 miles on a xcar 150a esc had lots of fun …you need to get the pc program working the interface on that card sucks but useable…bet the driver didnt install with the program. Uninstall restart install restart then plug in card…see does that work
