taycro
August 8, 2017, 10:10pm
1
I am finally ready! First off, thanks to everyone who helped me get to where I am now. This is what I have got currently:
• Deck (9.5" x 42" deck) - https://www.amazon.com/Longboard-Deck-Freestyle-Canadian-Stained/dp/B01860EFP6/ref=sr_1_13?ie=UTF8&qid=1500953779&sr=8-13&keywords=longboard+deck+only
• Trucks (10 inch 50 degree Reverse King Pin Caliber trucks) - https://www.amazon.com/dp/B0719BXH7G/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&%3Bcolid=2GG913J9QF9WG&%3Bcoliid=I1B2UMNYLAUIQY&th=1&psc=1
• Wheels and Bearings (90mm center set urethane wheels) - https://www.amazon.com/Longboard-Flywheels-Owlsome-Precision-Bearings/dp/B01IBJ5ZL0/ref=as_sl_pc_tf_til?tag=bigkidsoffici-20&linkCode=w00&linkId=21b04518cc9c9c34423701371bc9fbb3&creativeASIN=B01IBJ5ZL0
• 15mm Pulley Combo Kit (15T Motor Pulley, 36T Wheel Pulley, Retainer/Washer for bolts, 265mm Long Belt HTD 5 M, 265mm Long Belt HTD 5 M, (6) M6 Allen Head Screws) - http://www.ebay.ca/itm/15mm-DIY-Electric-Skateboard-Wide-Belts-ABEC-Flywheel-Pulley-Skateboard-Part-Kit-/311929901467
• Motor Mount - Self-made
• Motor (6374 192KV 2750W) - https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html
• VESC - diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
• Wireless Control/Receiver - Self-made or http://www.ebay.com/itm/Mini-Remote-Controller-w-Receiver-Electric-Skateboard-Longboard-2-4GHz-US-Seller-/172680052651?nma=true&si=tQidMJVB45iUFM9owitJzhY0iSg%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Anti Spark Key - https://www.amazon.com/XT90-S-Female-Connector-Battery-Charge/dp/B00RVM8U5W/ref=sr_1_1?s=toys-and-games&ie=UTF8&qid=1502478742&sr=1-1&keywords=xt90+anti+spark&refinements=p_36%3A-600
• Battery (6Ah 12s2p 44.4V) with Charger - https://miamielectricboards.com/shop-1/stealth-packs
• Battery Indicator (12-48V) - https://www.amazon.com/gp/product/B01LQ7MT4K?ref_=oh_aui_detailpage_o00_s00&redirect=true&psc=1&pldnSite=1
• Enclosures - Self-made
• Shock Pad Risers - Self-made
• Bumpers - Self-made
Extras:
• 10-12 AWG High Strand Silicone Wire
• Loctite Glue
• Male to Male Servo Connector
• Grip Tape
• Heat Shrink 8mm
My goals:
• 20+ mph
• 20+ mile range
• climbs hills with ease
• don’t spend a fortune
Wiring:
Specs:
At this point I am looking for people to help me finalize my plan. That could be by giving me tips, trick, suggestions, concerns, part swaps, etc. Anything at all would be greatly appreciated.
twan
August 8, 2017, 10:20pm
2
I don’t think your battery of 5ah will get you 20mile range . Having fast and long distance board doesn’t come cheap
SyrusB
August 8, 2017, 10:42pm
4
so are you doing a 5s build? because to get 10,000mah you will have to put them in parallel.(long range slow top speed). and if you put them in series it is only 5000mah.(faster speed shorter range) if i were u buy a battery for @oriol360 12s2p it is $200 but is worth it it comes with a charger and everything u need because it is only like $50 more.
Well you should probably read up more on series and parallel you will only get like 10 miles from those batteries
SyrusB
August 8, 2017, 11:45pm
8
Also the switch that you picked will blow out because it is rated for 5v-12v
taycro
9
@SyrusB The power button… why?
SyrusB
August 8, 2017, 11:54pm
10
Because the batteries are to powerful as in to high of a voltage
taycro
August 8, 2017, 11:55pm
11
SyrusB
August 9, 2017, 1:52am
14
i see your setup and it is the exact same as mine that thing will fly i hit 30.78 mph i am 140lbs
taycro
August 9, 2017, 1:54am
15
can u send me you set up with all ur parts?
SyrusB
August 9, 2017, 4:13am
16
ELECTRIC SKATEBOARD
Vesc
99.99
Motor Mount and Drive Kit
diy-electric-skateboard-kits-parts/single-bolt-on-motor-mount-with-drive-wheel-kit/
106.99
Free delivery on millions of items with Prime. Low prices across earth's biggest selection of books, music, DVDs, electronics, computers, software, apparel & accessories, shoes, jewelry, tools & hardware, housewares, furniture, sporting goods, beauty & personal care, groceries & just about anything else.
Trucks
https://www.amazon.com/dp/B00O05W0VI/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2GG913J9QF9WG&coliid=I1B2UMNYLAUIQY
39.95
Bearings
https://www.amazon.com/Bones-Bearings-Reds-Spacers-Washers/dp/B00L1SY9O8/ref=pd_sbs_468_3?_encoding=UTF8&pd_rd_i=B01E4GC094&pd_rd_r=90HYZ9E906JRZSJY9Y9F&pd_rd_w=dDj8W&pd_rd_wg=5792b&refRID=90HYZ9E906JRZSJY9Y9F&th=1&psc=1
12.90
Wheels
https://www.amazon.com/dp/B00EYDHWTQ/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2GG913J9QF9WG&coliid=IMCLJ390YT0S1 ,
60.00
Riser Pads
https://www.amazon.com/Drop-Through-Rubber-Riser-Pads/dp/B00B2Q1OL0/ref=sr_1_sc_2?ie=UTF8&qid=1481395963&sr=8-2-spell&keywords=riser+pads+longboard+dropthroug
4.99
Controller
https://www.amazon.com/gp/aw/d/B00FS2U9BA/ref=mp_s_a_1_1?ie=UTF8&qid=1502251493&sr=8-1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=gt2b&dpPl=1&dpID=31mLTKR%2BCfL&ref=plSrch
27.98
Volt Meter
https://www.amazon.com/gp/aw/d/B00NZV7K3G/ref=mp_s_a_1_1?ie=UTF8&qid=1502251706&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=Waterproof+Monitor+DC+4.5-150V+12%2F24%2F36%2F48V+Volt+Battery+Meter+Voltage+Tester+Automative+Electric+Cars+Gauge+Golf+Cart+E-Bike+Bicycle+Motorcycle+Small+Digital+Voltmeter+0.56 "LED+Blue&dpPl=1&dpID=518hIwxSs-L&ref=plSrch
9.99
Anti spark switch
https://www.amazon.com/gp/aw/d/B00WND5KFW/ref=mp_s_a_1_3?ie=UTF8&qid=1502251792&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=xt90+anti+spark&dpPl=1&dpID=41zZ-VmmywL&ref=plSrch
4.99
Motor
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor . html
79.96
Tactics.com
Deck
http://www.tactics.com/sector-9/lookout-41125-bamboo-drop-through-longboard-deck
72.00
Miamielectricskateboards.com
Battery
200
EXTRA
Wire
Solder
XT90S bullet connectors
JB Weld
Locktight
SyrusB
August 9, 2017, 4:15am
17
SyrusB
August 9, 2017, 4:16am
18
I used to get around 10 miles on my 12s 5ah battery.
12s full charge voltage is 50.4v
taycro
May 10, 2018, 4:21am
21
@onloop can you delete this thread
Deckoz
May 10, 2018, 10:32am
22
You could have just let it stay way in the backlog… It already died, and you resurrect it 9 months later just to ask for it to be deleted?
