Hi all community I just bought the whole set up include new motor and VESC, i ran into a weird issue when my motor seem to brake ( or not spinning all of the sudden ), when running at slow speed, it shakes a lot and not spin at all, cause me to fall off the board. it happens a lot of time, i included a video below. Sorry for my english, any advise would be highly appreciated !
Did you run motor detection on the vesc and apply the values?
Yes i did Jlabs, i applied them and tried again, still have same issue
Post some screenshots of your Motor Config, BLDC, App Config, and PPM tabs (helps us help you).
Looks like your using @Ackmaniac’s too. You’ll want to change to watt control no reverse with brake in the PPM tab.
When you run motor detection you have to follow these steps, it may throw off your results if you dont:
- Select disabled in the PPM tab
- Reboot the VESC & reconnect when its done rebooting
- Run motor detection
- Select watt control no reverse with brake in the PPM tab
so i follow those step and i dont see it happens as much as before but still sometime, but i notice the issue will happen when : pull the throttle too fast ( from 50% to 100%) it will likely happen, if i slowly go up then it wont,
You wont do that while riding and bench test dont provide an accurate acceleration curve anyway. Should be normal when riding. Your settings look pretty good to me.
Also, what is your battery chemistry and voltage? Your cutoff is a bit high.
JLabs, the battery is graphene 10000mah 6S 15C, waht should i set my cutoff too, i changed it to the wattage mode like u said, i will go to field test it and comeback with result !
You can go to 3v per cell with a lipo minimum. Not sure if it’s the same for grahpene or not.
