I’m selling a used Torque Boards motor, I had for my first 8s build. I have since moved on and have no use for it anymore.
This is a sensored 5055, 280kv(I found to be more around 260kv) great little motor. On 6s I got about a 24mph top speed and on 8s, it was just around 30mph(90mm wheels, 16:36). It has a long shaft, with a keyway slot(keyway itself not included) and flatspots. To date, it is my most efficient motor, giving me around 12wh/mi. I only weigh about 130lbs and I used it as a single motor board, which for me worked just fine. Also, if you plan to use the sensor function on a vesc, ill include the connector you could solder onto the current one to be able to plug into vesc. Other than scratches from normal use, it is in perfect condition. $50 Shipped in the U.S.
