Hello all. I’m having an issue with my TorqueBoards 2.4Ghz Nano remote showing a constant, flickering throttle response around 1.54ms. The controller seems to sync properly. I am throttling fully forward and backwards when powering on, as I have read elsewhere that this controller must be calibrated at each boot. But I still see no response in VESC Tool when throttling the controller. When I switch to “Current No Reverse With Brake” and try to control the motor with my keyboard arrow keys, I hear a crackling sound and the motor doesnt spin. When the controller type is changed to “Off” the keyboard arrows can control the motor.
Attached are a few screenshots and a snapshot of the wiring. Please advise if you think that my controller is defective or if I am missing a step.
I don’t see the option to set the mode to PPM. From the left column, I am in the PPM settings and on the “General” tab. I have set the Control Type to “Current No Reverse With Brake”
Through the Input Setup Wizard, I did select PPM controller upon initial.
I had not…but now set to PPM and written to the VESC. Still not responding.
It was set to PPM and UART. Should I concern over the settings below this such as Send CAN Status and Can rate? I assume this is for a dual VESC build which mine is not.
I just made an observation. When the controller is off, I am still receiving that flickering signal around 1.54ms in VESC Tool. Shouldnt it be static at this point?
